I am simulating a classD audio PWM amplifier loop with spectre.
The idle channel pss condition of the amplifier is a 50% duty
cycle squarewave. I get the PSS analysis to converge properly
under this condition.
I have a few questions : ???
1) When I do PNOISE on the ouput (a 50% duty cycle
squarewave), does it reflect an idle channel measurement?
2) Since the output is really a continuous time signal, should I use the
PNOISE option "sources"?
3) When using this option does spectre do a noise calculation all over the periodic signal?
4) Since there is a comparator in the analog loop, does the PNOISE
still hold valid?
TIA for any advice/suggestions/answers....
