Apr 27th, 2024, 8:44pm
array of random numbers (Read 2775 times)
Jeremy Lubkin
Guest
Jul 02nd, 2004, 2:51pm
I am trying to generate an array of uniformly distributed numbers at the beginning of a verilogA module.  I want this array to be initialized at startup.
The ultimate goal is to generate a noise signal - this signal would consist of equal spaced, equal magnitude, random phase sine waves that are added to the input.  The way I am doing this is going thru a for loop (i = num noise sources) and adding in a sine wave to a running noise signal - which I add to the input signal at the end.
I discovered I cannot have a random function in a loop - so I was going to pre-generate an array (longer than any expected number of sources) of random variables and just access this array within my loop.
I dont know how to set up this array of unif. random numbers.
Would appreciate input.
Jeremy
  IP Logged
Re: array of random numbers
Reply #1 - Jul 6th, 2004, 8:46pm
This is due to be fixed in this PCR:
   PCR: 585550
 Title: random, dist_normal etc cannot be used in iterations
It was supposed to be in IC5033USR2 and IC5141, but for some reason isn't, which I'm looking into right now.
