aznaragorn
I am trying to use connect modules to use both analog and digital inverters. right now my code looks like this:
module test();
reg a; logic a; wire b,c,d; logic b,c,d; wire temp; logic temp; initial a = 0; initial begin forever a = #100 ~a; end assign temp = a; analog_inv a1 (temp,b); analog_inv a2(b,c); endmodule
I have 2 connect modules defined elsewhere called a2d and d2a which are similiar to the ones posted on the designers guide website.
I get this error message on the line analog_inv a2(b,c): ncelab : Segmentation of a signal between analog ports is illegal
Any ideas on what this means and how to fix it?
