May 16th, 2024, 12:11pm
"generate" Statement (Read 7398 times)
Nader
Guest
Jul 29th, 2004, 8:59am
I am using the veriloga "generate" statement  in the veriloga definition for a 28 bit adder used inside a delta sigma modulator.
It takes an unusually long time for the syntax check to be completed.   There are no errors and the adder produces the correct results in simulation.  However the simulation takes a long time to get started.
Origially I had implemented the adder with a cascase of two bit full adders.  I thought I could speed up the simulation by consolidating the adders into one defintion file.  However the consolidated 28 bit definition is even slower than the cascade of two bit adders.
I suspect that this is due to some inefficiency in the "generate" statement.  Is that the case?
Is there a better alternative?
Any comments would be greatly appreciated.
--Nader
  IP Logged
Re: "generate" Statement
Reply #1 - Jul 30th, 2004, 12:20am
The generate statement effectively unrolls the loop in order to generate distinct contribution statements for each member of the bus - without seeing the code, it's hard to know why it is inefficient.
The alternative would be genvar (but that's not supported in spectre yet) - but I don't see why that would be any more efficient.
What does the code look like?
Nader
Guest
Reply #2 - Jul 30th, 2004, 11:48am
Thank you for your reply Andrew.
Here is the entire code below.  The formatting got a bit messed up when I cut and pasted it here but I hope that it is readable.
Basically the code tries to add two values x and y which are 28 bits long and output the sum and the carry.
Nader
`include "constants.h"
`include "discipline.h"
module pll_add28_va(z, x, y);
output [28:0] z;
electrical [28:0] z;
input [27:0] x;
electrical [27:0] x;
input [27:0] y;
electrical [27:0] y;
parameter real vlogic_high = 1.2;
parameter real vlogic_low = 0;
parameter real vtrans = (vlogic_high + vlogic_low)/2;
parameter real tdel = 60p from [0:inf);
parameter real trise = 40p from (0:inf);
parameter real tfall = 40p from (0:inf);
  integer  a[27:0], b[27:0], c[27:0], p[27:0], g[27:0];
  real S_val[27:0],i;
  real CO_val;
 analog begin
    generate i (0,27,1) begin
       a[i] = V(x[i]) > vtrans;
       b[i] = V(y[i]) > vtrans;
           @ (cross(V(x[i]) - vtrans, 1))   a[i] = 1;
           @ (cross(V(x[i]) - vtrans, -1))  a[i] = 0;
           @ (cross(V(y[i]) - vtrans, 1))   b[i] = 1;
           @ (cross(V(y[i]) - vtrans, -1))  b[i] = 0;
//generate Pi and Gi
     p[i] = a[i] ^ b[i];
     g[i] = a[i] & b[i];
     if(i >= 1) c[i] = g[i-1] | (p[i-1] & c[i-1]);
                  else c[i] = 0;
     S_val[i] = (c[i] ^ p[i]) ? vlogic_high : vlogic_low;
     V(z[i]) <+ transition( S_val[i], tdel, trise, tfall);
    CO_val = (g[27] | (p[27] & c[27])) ?    logic_high :vlogic_low;
    V(z[28]) <+ transition( CO_val, tdel, trise, tfall);
  IP Logged
