Nader
Guest
Thank you for your reply Andrew.
Here is the entire code below. The formatting got a bit messed up when I cut and pasted it here but I hope that it is readable.
Basically the code tries to add two values x and y which are 28 bits long and output the sum and the carry.
Nader
`include "constants.h" `include "discipline.h"
module pll_add28_va(z, x, y); output [28:0] z; electrical [28:0] z; input [27:0] x; electrical [27:0] x; input [27:0] y; electrical [27:0] y;
parameter real vlogic_high = 1.2; parameter real vlogic_low = 0; parameter real vtrans = (vlogic_high + vlogic_low)/2; parameter real tdel = 60p from [0:inf); parameter real trise = 40p from (0:inf); parameter real tfall = 40p from (0:inf);
integer a[27:0], b[27:0], c[27:0], p[27:0], g[27:0]; real S_val[27:0],i; real CO_val;
analog begin
generate i (0,27,1) begin a[i] = V(x[i]) > vtrans; b[i] = V(y[i]) > vtrans;
@ (cross(V(x[i]) - vtrans, 1)) a[i] = 1; @ (cross(V(x[i]) - vtrans, -1)) a[i] = 0;
@ (cross(V(y[i]) - vtrans, 1)) b[i] = 1; @ (cross(V(y[i]) - vtrans, -1)) b[i] = 0;
//generate Pi and Gi p[i] = a[i] ^ b[i]; g[i] = a[i] & b[i]; if(i >= 1) c[i] = g[i-1] | (p[i-1] & c[i-1]); else c[i] = 0;
S_val[i] = (c[i] ^ p[i]) ? vlogic_high : vlogic_low; V(z[i]) <+ transition( S_val[i], tdel, trise, tfall); end
CO_val = (g[27] | (p[27] & c[27])) ? logic_high :vlogic_low;
V(z[28]) <+ transition( CO_val, tdel, trise, tfall);
