May 5th, 2024, 5:16am
help me about VCO design (Read 2356 times)
VincentLee
Aug 09th, 2004, 1:27am
hi,
I have met a troublesome problem when I design a ring VCO that includes 2 parts--control voltage to current and current to frequency. The output frequency changes with the process corner and temperature. I think main reason is the structure of control voltage to current, which is a nmos follower and a resistor. Under different process corner, the resistor changes about 20% in my process model, so the output frequency also changes.
I think the circuit of converting control voltage to current has a few requirements:
1. the linearity--which ensures the linearity between control voltage and output frequency
2. the stability under different temperatures
3. the stability under different process corners
4. the stability under different power supply voltages
If different PVT can affect the current remarkably, then the performence of VCO is not good enough inevitably.
So who can help me to obtain a "perfect"(relative) structure of voltage-->current in VCO? Any useful information or reference are appreciated!
Thanks a lot in advance!
Best regards,
Vincent
try my best...
Frank Wiedmann
Munich, Germany
Re: help me about VCO design
Reply #1 - Aug 10th, 2004, 1:44am
If you cannot meet the specification for your circuit over PVT variations, I see the following options:
Use external components with a higher precision than what is available on chip, e.g. an external precision resistor. This will cost you an extra pin and, depending on the structure of your circuit, might lead to stability problems if the capacitive load at the pin is too high.
Provide a possibility to tune the circuit after fabrication by setting on-chip switches, blowing fuses etc. This will usually increase production costs because of the additional effort required to adjust the performance.
