Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
May 2
nd
, 2024, 5:06am
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› Fractional Divider in Reference Path of PLL
Previous topic
Next topic
Fractional Divider in Reference Path of PLL (Read 3061 times)
Daniel Nobonzo
Guest
Sep 10
th
, 2004, 12:52am
I wonder if there is any drawback in placing a fractional divider (noise, spurs, ..) in the reference path, i.e. after the crystal, instead of after the VCO.
Thanks for your comments.
Dan
IP Logged
emad
Cairo, Egypt
Re: Fractional Divider in Reference Path of PLL
Reply #1 -
Sep 10
th
, 2004, 8:01am
It is actually both!
A fractional divider based on DS modulation is pretty noisy. That is because the quantization noise shows as shaped noise with 20*(n-1) dB/dec, where n is the modulator order. This noise at the reference will be further magnified by 20*log(N), where N is the feedback divider ratio.
Same happens for spurs.
For the reference section you want a quiet configuration. You simply can't afford to mess up there.
IP Logged
strabush
Guest
Reply #2 -
Jan 10
th
, 2005, 5:58am
Matter of fact, A DDS as the reference is exactly that.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
