Nov 7th, 2026, 8:58pm
signed logical operations in VHDL (Read 4405 times)
neocool
Sep 10th, 2004, 10:06am
I am fairly new to VHDL.
I am designing BPSK modulator and want it to output unsigned or 2's compliment format depending on the register settings I choose (so software selectable). I am wondering, how would you work with unsigned and 2's compliment in VHDL. Do you have to do all math manually or there are any special functions that can sum/subtract two 2's compliment numbers automatically? I have to use multiplication and addition of signals in my code.
Thanks for any help in advance
Paul
Switzerland
Re: signed logical operations in VHDL
Reply #1 - Sep 13th, 2004, 11:57am
you can define your signals as unsigned, a predefined signal type. All operations on this type are predefined too.
As far as I remember, synthesis tools also understand 'unsigned' correctly and the signals will be synthesized as a n-bit logic signal.
Paul
neocool
Reply #2 - Sep 21st, 2004, 10:04am
thanks
I've partially answered this question myself. Apparently, signed ports did not work for me. I had to cast slv to signed, then do multiplication and then cast it back to slv. THe result contained 2's compliment number
thanks
