Why cannot you use minimum length for pass transistor. Although the minimum channel length is avoided when designing opamp, current mirror, etc., I think it is a good choice when you design a pass transistor.
We choose longer channel length for good matching, noise consideration. But for a pass transistor used in a voltage regulator, the concern is small series resistance.
Do you agree with me?
Yawei
