May 17th, 2024, 7:37am
Problems for minimum Length in Analog circuits (Read 2599 times)
vishwanath
Oct 13th, 2004, 1:55am
HI,
I designed Voltage regulator using NMOS pass transistor, Here, I used NMOS with w=5u, l=0.35u and M=6 to get low resistance. Can we use minimum length for analog circuits... if not what problems...
vishwanath
Re: Problems for minimum Length in Analog circuits
Reply #1 - Oct 13th, 2004, 3:28am
Why cannot you use minimum length for pass transistor. Although the minimum channel length is avoided when designing opamp, current mirror, etc., I think it is a good choice when you design a pass transistor.
We choose longer channel length for good matching, noise consideration. But for a pass transistor used in a voltage regulator, the concern is small series resistance.
Do you agree with me?
Yawei
