Jul 22nd, 2024, 3:20am
THA Design (Read 1896 times)
codec
THA Design
Nov 03rd, 2004, 4:29am
I met difficulty in THA design of the pipelined ADC. The T/H circuit has a worst case THD of 72dB@1.875MHz(fs=60MHz) but 55dB@58.125MHz(fs=60MHz). In such case, what should I focus on in order to improve the performance? Any adivce or recommended paper?
Thanks a lot!
Re: THA Design
Reply #1 - Nov 5th, 2004, 6:23am
First of all, I want to know how do you measure THD of the THA.  :)
When I simulate THA, I measure THD using FFT analysis. It is important to control the start time and step of FFT because the Track and hold is a one-order sample and hold. Do you think so?
About your problem, THD decreases as the input frequency increases because of finite input bandwidth. I think you should lower the on-resistance of input switch or lower the capacitance of the sampling capacitor. Smiley
Best regards,
Yawei
codec
Re: THA Design
Reply #2 - Nov 5th, 2004, 7:51am
Thanks, ywguo!
I also use FFT to measure THD.  I set fin=fs/32 and take 64 points or above to calculate FFT.
The Fu of THA amp is about 600MHz and it is a flip-around THA structure. I also suspected that Ron of SW was too high, but when I used ideal SW with Ron as low as 50~100ohm, the THD was not improved. (It is also this simulation let me select CMOS SW instead of boostrapped SW)
What about your simulation result?
BTW, I use Spectre .
microant2000
Ex Member
Re: THA Design
Reply #3 - Nov 7th, 2004, 10:49pm
hello,
I want to know the resolution of your THA,and what do you mean in your article "55dB@58.125MHz",it seems that the measure is in the undersampling condition.
Do you measure the sample switch' THD? it will limit the THA performance.about the  on-resistance , i think you should make it constant ,not lower.
sorry, my English is poor, i hope you can understand my ideal. Cheesy
Best regards,
microant
  IP Logged
codec
Re: THA Design
Reply #4 - Nov 9th, 2004, 3:25am
Thanks, MicroAnt
It is true that constant Ron(Vin) is of most importance. These days, I chaned the switch to bootstrapped type and archieved a better THD of 65dB@61.875MHz. (undersampling mode)
But I am wondering whether such simulation is necessary.
Re: THA Design
Reply #5 - Nov 15th, 2004, 3:53am
Hi, Codec,
Have you measured the on-resistance of the switches? I wonder the relationship between the resistance and the THD.
The THD of the THA is necessary because it decides the THD of whole ADC. Smiley
Yawei
codec
Re: THA Design
Reply #6 - Nov 16th, 2004, 7:23pm
Hello,  Yawei
Ron is around 60~100ohm in my design.
I mean whether it is necessary for me to simulate the circuit under the condition of "undersampling"? In real application, would such case occur?
Re: THA Design
Reply #7 - Nov 19th, 2004, 7:16pm
Codec,
Ron is around 60~100Ohm for bootstrapped swtich? That is very near Ron in my design, which is a 40MHz, 10bit IF-samping ADC.
The undersampling depends on your application. For eg., an IF-sampling ADC used in DVB-C demodulator.
What is your application?
Best regards,
Yawei
codec
Re: THA Design
Reply #8 - Nov 30th, 2004, 2:52pm
Hi, Yawei
Sorry for my late reply. I was busy working these days.
My current design is for the request of a custom.  It is said to be a video application.
BTW, have you done the post-layout simulation?
When I was doing the post simulation on the THA block, I found that the THD degradated for near 10dB. I am trying to find the problem. Have you any ideas?
Thanks.
