May 3rd, 2024, 8:11am
inductor losses (Read 2263 times)
logan
Guest
inductor losses
Nov 12th, 2004, 2:04pm
Q. is it not abnormal that I get a difference of 9 dB in losses between an ideal inductor and one from the model library ( i am using austriamicrosystems 3 metal cmos 0.35u) thanks
  IP Logged
jefkat
Re: inductor losses
Reply #1 - Aug 11th, 2005, 5:18am
well depnds on
>Number of turns
>inter filament spacing
>Area left in the middle
>And o course the freq..
you get the best Q (the minimum loss) for a (/or more) combination(s) of the above factors..
The otherway to check is to read the manual of technology..
hope it helps.
Shafkat
