May 18th, 2024, 12:18pm
Rise and Fall time (Read 2957 times)
ramus12
Rise and Fall time
Nov 17th, 2004, 12:46pm
hi,
what is the ideal rise and fall time that can be specified in the cadence Spectre simulator using IBM 130nm technology?
I am using inuts with the period of 1n, 2n, 4n etc.
Re: Rise and Fall time
Reply #1 - Nov 19th, 2004, 7:10pm
When you are not confident on the transition time (rise time or fall time), you'd better drive your cricuit with a desired buffer.
You should consider which cell will drive the input (data or clock input). Then use that cell to drive your circuit. So you needn't worry the rise/fall time.
By the way, the transition time of 130nm technology must be much less than 1ns.
Best regards,
Yawei
