Jul 22nd, 2024, 1:15am
About PSRR (Read 3124 times)
serdes
About PSRR
Nov 17th, 2004, 11:41pm
Hello everyone
  I have been confusing by the psrr,such as in op or bandgap,ldo. I can`t know how to figure the impact
on my circuit,especially on op.Can you  show me some marterial on it?
 Best regards
Re: About PSRR
Reply #1 - Dec 10th, 2004, 7:30pm
  Don't have any material just some comments:
1) Simply put power supply are inputs. PSRR gives the ratio
   of the gain from the power supply to the output over the
   gain from the standard inputs to the output.
2) While PSRR is typically specified as XdB at YHz, you also
    need to consider the dc levels of the  inputs, the
    output, and the power supply. All of the dc levels and
    can effect the ac results.
3) Depending on the circuit, i.e., differential circuits, there
   may be canceling due to symmetry. In that case, you
   need to analyze the effect of device mismatch on PSRR.
4) Measure the open loop gain, and then move  ac
   input to the power supply terminal and then take the
   ratio., the ADE calculator is good for this type of
   calculation.
