Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Apr 29
th
, 2024, 4:55am
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› IM3 --> IP3
Previous topic
Next topic
IM3 --> IP3 (Read 9497 times)
Jeffrey
Guest
IM3 --> IP3
Dec 02
nd
, 2004, 8:13pm
What is the relation between IM3 (3rd order intermodulation component) and IP3 (third-order intercept point)? How do I convert from IM3 to IP3?
IP Logged
Re: IM3 --> IP3
Reply #1 -
Dec 2
nd
, 2004, 9:54pm
The IP3 "tree" looks like this:
IM3
1
IF
1
IF
2
IM3
2
If the input power is
P
in
, then the input referred IP3 is
P
in
IF
1
IM3
2
)/2
or
P
in
IF
2
IM3
1
)/2
This is fairly obvious if you plot the intercept point, since the IF's will increase at 1dB/dB and the IM3's will increase at 3dB/dB (assuming no compression, which is how the intercept point is computed).
I just remembered that this is covered in Ken's paper:
http://www.designers-guide.com/Analysis/intercept-point.pdf
IP Logged
hrkhari
Re: IM3 --> IP3
Reply #2 -
Dec 18
th
, 2004, 9:41pm
Hi Guys:
Which value is significant in active mixer design, IIP3 point or OIP3 point, in my design of mixer I obtain an IIP3 point of 13.39dBm but a corresponding output OIP3 point of -21.07dBm, I understand that the IIP3 point should be as high as possible to alleviate the IM3 distortion, how does OIP3 signify?. Thanks in advance
Rgds
IP Logged
maserati
Re: IM3 --> IP3
Reply #3 -
Jan 26
th
, 2005, 4:20pm
In your case, it sounds like the IN->OUT signal path has about 35dB gain.
If the gain is fixed, the IIP3 and OIP3 basically is same, theoretically.
However, if the Gain veries, the IIP3 will change as well.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
