May 15th, 2024, 12:05am
Filter Specification in CDMA IS95 (Read 3560 times)
chingkailun
Malaysia
Dec 25th, 2004, 7:35am
I am doing bandpass filter for wireless receiver front end(IF conversion architecture). The filter is IF filter which is situated right after the mixer.
Is there any standard specification for the filter(CDMA IS95 standard)?
I know the standard bandwidth of the filter in CDMA is 1.25MHz.
If anyone knows the standard such as
1. centre frequency,
2. gain,
3. input equivalent noise/noise figure,
4. linearity(IP3/compression point),
5. attenuation, and others relevant info, plz let me know.
Thanks!I really need your help...
Kailun
View Profile 146408118   IP Logged
DaveB
Re: Filter Specification in CDMA IS95
Reply #1 - Jan 11th, 2005, 8:16pm
I'm not sure that I'm  reading your request correctly, but here it goes. Bandpass filters for RF are generally passive, crystal or SAW based devices.
1) The center frequency is your IF Frequency
2) Gain (Loss Actually) is as small as possible.
3) Noise figure is the inverse of the gain
4) Linearity generally isn't a concern for filters.
5) Those are really the big ones. You might want to think about spurious rejection and ultimate attenuation floors as well, but that is left as an exercise for the student  :)
boa
Reply #2 - Jan 11th, 2005, 9:09pm
I think that the answers to you questions are not in the CDMA standart, but depend on the frequency planning of your receiver.
DaveB
Reply #3 - Jan 15th, 2005, 11:47am
Boa:
you are right, most of these fall into fairly generic Front end design.
Dave
