May 20th, 2024, 2:41am
Problem in SC filter simulation (Read 4394 times)
shyboy
Jan 04th, 2005, 8:37pm
I was trying to simulate an SC lowpass filter using spectre and I found that the output is very small, almost zero...So i guess i didn't give the correct input signal...
The input i used was a dc voltage source with dc level 1V and a PAC of 1V...Can anyone tell me whether this input is correctly set? If not, how should I set it?
Thanks~~
shyboy
Re: Problem in SC filter simulation
Reply #1 - Jan 4th, 2005, 9:47pm
Well, without knowing what analyses you ran, it's hard to know...
shyboy
Reply #2 - Jan 4th, 2005, 10:00pm
Hi, Andrew,
Thanks for your reply...I am new to cadence, so i may be asking silly questions...Is it true that, to simulate an SC filter using Spectre, I need to run a PSS analysis followed by a PAC analysis? Can I simply use just an AC analysis?
shyboy
Frank Wiedmann
Munich, Germany
Reply #3 - Jan 4th, 2005, 11:37pm
Yes, you need to run a PSS analysis followed by a PAC analysis. No, you cannot simply use just an AC analysis. Have you already read http://www.designers-guide.com/Analysis/sc-filters.pdf ?
shyboy
Reply #4 - Jan 5th, 2005, 6:25pm
yes, i did read that paper, but i don't quite understand it...Could you kindly clarify some of my doubts?
1. Vin: if i set the type to dc, how can i specify the frequncy, amplitude, etc.? And where can i find the "alter" statement?
2. pss analysis: What are fundamental tones and beat frequency and what is the correct manner to specify them? And where can i specify the maxacfreq? Also what are the parameters in Options that are normally specified during SC filter simulation?
3. pac analysis: what effect does maxsideband have on the sim result? The paper mainly talked about the effect of maxsideband in the noise analysis, i think...
Sorry for so many questions...BTW, i am a student struggling with a design project, and i don't have much background on this project...So any help from you guys will be appreciated...
Reply #5 - Jan 11th, 2005, 4:22pm
You could always read the documentation, or do you want us to do that for you as well?
Sorry for the cutting remark, but there is some fairly decent documentation for SpectreRF which would get you most of the way there.
