Nisha
Guest
Try this!! this is a rate multipiler.. the values of M and N are decided by the GCD.. for 5.5 these will be 11 and 2.
library ieee ; use ieee.std_logic_1164.all ; use ieee.std_logic_signed.all ;
entity rate_multiplier_demux is port( arst :in std_logic ; clk_vco :in std_logic ; clk_out :out std_logic ) ; end rate_multiplier_demux ;
architecture rate_multiplier_demux of rate_multiplier_demux is
component delayst_demux is generic(D :integer range 1 to 50 := 1 ; in_width :integer range 1 to 50 := 2) ;
port( arst :in std_logic ; clk :in std_logic ; clk_en :in std_logic ; data_in :in std_logic_vector(in_width - 1 downto 0) ; data_out :out std_logic_vector(in_width - 1 downto 0) ); end component ;
component demux_vector_sel is generic(in_width :integer range 1 to 20 := 2) ; port( data_sel :in std_logic ; data_in1 :in std_logic_vector(in_width - 1 downto 0) ; data_in2 :in std_logic_vector(in_width - 1 downto 0) ; data_out :out std_logic_vector(in_width - 1 downto 0) ); end component ;
signal GND :std_logic ; signal VCC :std_logic ;
signal inv_clk_vco :std_logic ;
signal M :std_logic_vector(11 downto 0) ; signal N :std_logic_vector(11 downto 0) ; signal A_reg :std_logic_vector(11 downto 0) ; signal A_reg_in :std_logic_vector(11 downto 0) ; signal A_reg_l :std_logic_vector(11 downto 0) ;
signal B_reg :std_logic_vector(11 downto 0) ; signal B_reg_l :std_logic_vector(11 downto 0) ;
begin
GND <= '0' ; VCC <= '1' ; M <= "000001000011"; N <= "010000000000"; inv_clk_vco <= not(clk_vco) ;
A_reg <= A_reg_in - M ;
label3 :component delayst_demux generic map(1 , 12) port map(arst , clk_vco , VCC , A_reg , A_reg_l) ;
B_reg <= A_reg_l + N ;
label4 :component delayst_demux generic map(1 , 12) port map(arst , inv_clk_vco , VCC , B_reg , B_reg_l) ;
label5 :component demux_vector_sel generic map(12) port map(A_reg_l(11) , A_reg_l , B_reg_l , A_reg_in) ;
clk_out <= A_reg_l(11) ;
-- delay st!! library ieee ; use ieee.std_logic_1164.all ; entity delayst_demux is generic(D :integer range 1 to 50 := 1 ; in_width :integer range 1 to 50 := 2) ;
port( arst :in std_logic ; clk :in std_logic ; clk_en :in std_logic ; data_in :in std_logic_vector(in_width - 1 downto 0) ; data_out :out std_logic_vector(in_width - 1 downto 0) ); end delayst_demux ;
architecture delay of delayst_demux is
component reg generic( M :integer := 15) ; port( arst :in std_logic ; clk :in std_logic ; clk_en :in std_logic ; data_in :in std_logic_vector(M - 1 downto 0); data_out :out std_logic_vector(M - 1 downto 0) ); end component ;
type state is array(D downto 1) of std_logic_vector(in_width - 1 downto 0) ; signal temp : state ; begin
label1 :for i in 1 to D generate label2 :if(i = 1) generate label3 :reg generic map(in_width) port map(arst , clk , clk_en , data_in , temp(i)) ; end generate ; label4 :if(i /= 1) generate label5 :reg generic map(in_width) port map(arst , clk , clk_en , temp(i - 1) , temp(i)) ; end generate ; end generate ;
data_out <= temp(D) ;
end delay ;
--demux_vector sel library ieee ; use ieee.std_logic_1164.all ;
entity demux_vector_sel is generic(in_width :integer range 1 to 20 := 2) ; port( data_sel :in std_logic ; data_in1 :in std_logic_vector(in_width - 1 downto 0) ; data_in2 :in std_logic_vector(in_width - 1 downto 0) ; data_out :out std_logic_vector(in_width - 1 downto 0) ); end demux_vector_sel ;
architecture demux_vector_sel of demux_vector_sel is
begin
process(data_sel , data_in1 , data_in2) begin case data_sel is when '0' => data_out <= data_in1 ; when '1' => data_out <= data_in2 ; when others => data_out <= (others => 'Z') ; end case ; end process ;
--reg used in delay st
entity reg is generic( M :integer := 16) ; port( arst :in std_logic ; clk :in std_logic ; clk_en :in std_logic ; data_in :in std_logic_vector(M - 1 downto 0) ; data_out :out std_logic_vector(M - 1 downto 0) ); end reg ;
architecture reg of reg is
signal temp_data_out :std_logic_vector((M - 1) downto 0) ;
begin process(arst , clk , clk_en , data_in , temp_data_out) begin if(arst = '1') then temp_data_out <= (others => '0') ; elsif(clk'event and clk = '1') then if(clk_en = '1') then temp_data_out <= data_in ; else temp_data_out <= temp_data_out ; end if ; end if ; end process ;
end reg ;
