Hi, Codec,
My test system and instruments are listed below.
Sampling clock -- Agilent 33250A arbitrary waveform generator (poor sine signal, NOT suitable for analog input, but enough for sampling clock)
Analog input -- Tektronix AWG520 arbitrary waveform generator (better than Agilent 33250A). It has 10 bit D/A output, so filtering is required for measuring a 10 bit ADC.
Recording -- Tektronix TLA715 logic analyzer
Power supply -- HP6624 system DC power supply
You'd better use band pass filter for both sampling clock and analog input. I used Mini-Circuits SBP and SLP filter.
Please go to
www.maxim-ic.com. There are many good application notes about high-speed ADC testing. Basically I test my ADC according the method proposed by Maxim. But I don't have so good apparatus as those proposed in Maxim's application notes.
I advise you study the evaluation kit of Maxim, like MAX1448 Eval. Kit.
Would you please tell me some details of your design? Then perhaps I could give you more suggestions.
Good luck!
Yawei
