May 16th, 2024, 6:18pm
MOSFET non-linear operation for VDS_DC=0. (Read 3768 times)
Fernando_Rangel
Paris
Jan 19th, 2005, 11:27am
 I have to use a MOSFET operanting when the drain-source DC voltage is zero. VGS is chosen to be just a little higher than Vt.
 Normally, the MOSFET in this case would be in the lienar region, however, as we observed from measures of Ids when Vds is about some hundreds of microvolts @ 2.4 GHz, there are a very big DC component. This means that there are a great distortion here, not predicted by common foundry models.
 Does anyone have a clue about the MOSFET behavior under the circustances mentioned above ?
Thanks in advance.
Fernando
Kevin Gard
Guest
Re: MOSFET non-linear operation for VDS_DC=0.
Reply #1 - Apr 3rd, 2005, 8:20pm
There is a good conference paper on the topic from CICC 2004
RF distortion analysis with compact MOSFET models
Bendix, P.; Rakers, P.; Wagh, P.; Lemaitre, L.; Grabinski, W.; McAndrew, C.C.; Gu, X.; Gildenblat, G.;
Custom Integrated Circuits Conference, 2004. Proceedings of the IEEE 2004
3-6 Oct. 2004 Page(s):9 - 12
The basic answer is that the equations used to model velocity saturation for short channel devices may not have higher order derivatives at Vds=0V. In some models, this expression may have a singularity at Vds=0.
In the past, some engineers have used a small current source to force a small vds when using a floating fet.
  IP Logged
Reply #2 - Jun 6th, 2005, 8:22am
Fernando -
Are you saying you are *measuring* a distortion?  The paper Kevin cites shows why simulations erroneously predict distortion near Vds=0 because of poor formulation of the symmetry (drain-source swapping).
