May 1st, 2024, 1:49pm
long term jitter measurment. (Read 2506 times)
bhaijiamit
Jan 23rd, 2005, 11:29pm
I was trying a verilog-A model to calculate jitter and phase noise.  I have following issue regarding the measurement of long term jitter.  How exactly can i calculate the same. In my present verilog-A model for the VCO I am dumping the $realtime. To calculate the N-period long term jitter I am using following matlab commands
for I=1:1:100000,
    x(I)=time_long(I+nperiod)-time_long(I);
std(x)
(here nperiod is period for which I need to calculate the jitter and time_long is simulation dump file.)
Now my question is: since the division ratio in my design is 10, do  I need to divide this standard deviation by sqrt(ratio) as I would do if I were calculating the period jitter (I feel that I do not need to)?  Can anyone suggest a better method to measure the long term jitter?
Amit
« Last Edit: Jan 24th, 2005, 1:08am by Forum Administrator »
