Jul 18th, 2024, 5:29am
How to reduce noice figure? (Read 656 times)
richloo
Jan 26th, 2005, 5:41am
Hi guys, i am having too much NF(32dB) in my gm-C filter design. Any suggestion to reduce the NF? any trade-off?
thanks in advance!
101questions
Re: How to reduce noice figure?
Reply #1 - Jan 27th, 2005, 12:09pm
Well, Gm-C filters are not a good choice for low noise designs.
So what you get is somewhat expected.
If you insist on using Gm-C architecture, all I can suggest is to increase gm and C, if thermal noise is dominant, or mos areas if 1/f one is dominant.
richloo
Reply #2 - Feb 7th, 2005, 5:58pm
Thanks 101 for ur reply. The NF that i mentioned is using SP analysis. However, if i use conventional method to find noise rms,SNR, i get my NF around 4dB. I m not quite believing it., any comment?
thanks in advance.
