Aug 15th, 2024, 2:50am
Pages: 1 2
Op-Amp code and Ramp Input (Read 23476 times)
Vikram Srinivasan
Guest
Jan 27th, 2005, 3:03pm
Has anybody worked with a Verilog-AMS code for an op-amp?Can you share it with me?I have the one posted on this website , but I dont follow it entirely.
And how does one define a ramp(steadily increasing )dc input for a voltage source?
Vikram
  IP Logged
Re: Op-Amp code and Ramp Input
Reply #1 - Jan 28th, 2005, 10:35pm
First question - try ahdlLib (in the IC installation - e.g. IC5033, IC5141 etc) in:
<instdir>/tools/dfII/samples/artist/ahdlLib
There is an "opamp" model there.
You can also use the "modelwriter" tool to create an opamp verilog-a model.
Second question is answered in http://www.designers-guide.com/Forum/?board=verilogams;action=display;num=110506...
Vikram Srinivasan
Guest
Reply #2 - Feb 20th, 2005, 6:43pm
Hi Andrew
I have been using the op-amp model from the Cadence library. The amplification behavior is however not clear.
For instance,I built a voltage follower circuit to test the functionality of the model. Therefore, I used the code EXACTLY in the way it was in the cadence folder and I fed the output to the -ve terminal while giving a 1v dc source to the +ve terminal.
I find that the output is not equal to the input, it is infact ~3.05V; 3 times the input...I have not included any other elements here.
  IP Logged
Reply #3 - Feb 20th, 2005, 10:09pm
Vikram,
I did not see that behaviour. Did you wire it up correctly?
Here's my netlist:
// Generated for: spectre
// Generated on: Feb 21 06:03:48 2005
// Design library name: test
// Design cell name: testopamp
simulator lang=spectre
global 0
// Library name: test
// Cell name: testopamp
// View name: schematic
R0 (op 0) resistor r=1K
VREF (ref 0) vsource dc=1.5 type=dc
VDD (vdd 0) vsource dc=3 type=dc
V0 (inp 0) vsource dc=1 type=dc
I0 (op ref inp op vdd 0) opamp
    digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \
    sensfile="../psf/sens.output" checklimitdest=psf
dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
dcOpInfo info what=oppoint where=rawfile
subckts info what=subckts  where=rawfile
ahdl_include "/cds/hppa/IC5141_hot/tools.hppa/dfII/samples/artist/ahdlLib/opamp/veriloga/veriloga.va"
Note that originally I had the VREF source set to 0V, and I changed the 1.5V to see if that had an effect (it didn't). In my case the output was at 1V, as expected.
Vikram Srinivasan
Guest
Reply #4 - Feb 21st, 2005, 8:44pm
Hi Andrew
The following is my test bench for the voltage follower.As you can see, I tried creating a branch named "follow" between vout and vin_n. I have not created any other instances or made any other connections. I am giving a 1V dc to vin_p and supplyvoltages to vspply_p and vspply_n...
I see 1V at vin_p and vin_n. But for vout, I see a spike from 0V to 5V which quickly stabilises to ~3.05V...
Is this branch connection valid for the feedback?I tried defining
wire vin_n,vout;
But this gave me an invalid declaration error.
`include "disciplines.vams"
`timescale 10ps/1ps
module opampfollower(vout,vref,vin_p,vin_n,vspply_p,vspply_n);
inout vout,vref,vin_p,vin_n,vspply_p,vspply_n;
electrical vref,vout,vin_p,vin_n,vspply_p,vspply_n;
ground vref;
opamp opamp (vout,vref,vin_p,vin_n,vspply_p,vspply_n);
branch(vout,vin_n) follow;
vsource #(.type("dc"),.dc(1)) vin1(vin_p,vref);
vsource #(.type("dc"),.dc(2.5))vin2(vspply_p,vref);
vsource #(.type("dc"),.dc(-2.5))vin3(vspply_n,vref);
Unfortunately, I am using SimVision and I'm unable to compare my simulation to the Spectre output(although I understood what your pasted code described).
Thank you
Vikram
  IP Logged
Reply #5 - Feb 21st, 2005, 9:37pm
Vikram,
Your loop isn't closed. Simply defining a branch between vout and vin_n doesn't close the loop - it just defines a named branch that you can then use in the Verilog-AMS code.
If you add:
analog V(follow) <+ 0;
then that would solve the problem. Or, you could remove the branch and do:
analog V(vout,vin_n) <+ 0;
Or, more simply, you could change the opamp instance to:
opamp opamp (vout,vref,vin_p,vout,vspply_p,vspply_n);
i.e. change the vin_n connection to be vout.
Or you could have put another vsource in to close the loop.
Doing any of these things solves the problem.
If you'd entered a schematic and run AMS Designer through the environment, I'm sure you'd not have had a problem, because it would have been easy to connect up.
Alternatively, you should read the documentation carefully. I'd also recommend Ken and Olaf's book http://www.designers-guide.com/Books/#Kundert-2004 to learn basics like this.
Vikram Srinivasan
Guest
Reply #6 - Feb 23rd, 2005, 6:44pm
Hi Andrew
Well,I knew I could solve the problem by adding a source at vin_n as well as by creating an instance with 'vout' instead of 'vin_n'...but I wanted to know why the model didnt work with a branch.
Thanks very much for providing a list of options....I dont have access to Olaf and Kundert's book(although I need it badly)...that explains why I still have elementary questions propping up !!!
Thanks again
Vikram
  IP Logged
Reply #7 - Feb 23rd, 2005, 8:58pm
When you added the branch statement, you declared a branch, but you never described the branch. With no behavior described for the branch, Verilog-AMS defaults the branch to pass zero current. What you want is that there be no voltage across the branch. Thus, you have to add the statement that Andrew suggested ...
Vikram Srinivasan
Guest
Reply #8 - Feb 24th, 2005, 11:37am
Hey
Thanks Ken!I understand what I should be doing with branches now. This forum is a life-saver!
Vikram
  IP Logged
jk
fremont, CA
Reply #9 - Apr 3rd, 2006, 5:51pm
Hi Andrew,
I am also looking for a code for an OP-Amp(non ideal)
I am new to the forum and dont know how I should use the path you suggested to get the model -- pls suggest
Also Vikra, could you pls attach the cadence model that you mentioned.
Thanks a lot ...
View Profile jk jyotikukreja   IP Logged
Reply #10 - Apr 3rd, 2006, 10:57pm
The path I gave was to the ahdlLib library within the Cadence installation. If you add:
DEFINE ahdlLib $CDS_INST_DIR/tools/dfII/samples/artist/ahdlLib
DEFINE bmslib $CDS_INST_DIR/tools/dfII/samples/artist/bmslib
to your cds.lib file, you'll see these libraries within DFII.
You can also use the modelwriter tool to create behavioural models (just type modelwriter in a terminal window), and there's a model there for a non-ideal opamp.
There are also models at:
http://www.designers-guide.org/VerilogAMS/
That's the Verilog-AMS link at the top of the page... don't think there's a non-ideal opamp there though.
jk
fremont, CA
Reply #11 - Apr 4th, 2006, 6:54pm
Thanks a lot Andrew! This site is blessing ..especilally for novices like me Smiley
jk
fremont, CA
Reply #12 - Apr 11th, 2006, 11:54am
hi andrew,
Could you also tell me the textual reference of the Behavioural model (for non ideal OPamp) in the cadence ahdllibrary?
I am trying to understant the model but cant relate it to nay of the models i have come accress.
Also, I am having difficulties writing test benches/ stimulus for the OPamp (I want to try it in different closed loop configurations)
Could you point me to some examples or tutorials that would be able to help
Thanks again,
jk
Reply #13 - Apr 11th, 2006, 9:57pm
I don't understand what you mean by the "textual reference of the Behavioural model...".
As for tutorials for op-amp testbenches, I'd say that your best bet is to look in any books on op-amp design (e.g. Gray and Meyer, Allen and Holberg, Gregorian and Temes, etc - see http://www.designers-guide.org/Books).
jk
fremont, CA
Reply #14 - Apr 13th, 2006, 3:34pm
Hi Andrew,
What I mean is, is there any place where this model is described? As in a spec or document gives
more info about the INSTANCE parameters .
From the looks of it, I am not very clear of how this OPamp is modeled. So I need hlep in understanding it.
Thanks again
Jyoti
Pages: 1 2
