May 2nd, 2024, 10:56pm
ADC simulation/spec characterization (Read 1304 times)
jay
Feb 05th, 2005, 12:11am
Can you guys recommend a good reference on ADC simulation/full spec characterization? Many thanks!
Re: ADC simulation/spec characterization
Reply #1 - Feb 7th, 2005, 7:16am
Hi, Jay,
Go to www.maxim-ic.com. There are some very good application note about ADC testing.
Best wishes
Yawei
jay
Reply #2 - Feb 7th, 2005, 9:36am
[quote author=ywguo  link=1107591111/0#1 date=1107789385]Hi, Jay,
Best wishes
Yawei [/quote]
Hi, Yawei, I looked around maxim's web site. Looks like they only have actual ADC measurement test bench. Could you reommend some spectre/hspice simulation test benches? I'm not quite sure on the simulation setup for specs like INL, DNL, SFDR etc.
many thanks,
Jay
Leyman
Malaysia
Reply #3 - Feb 19th, 2005, 1:09am
Hi Jay,
I was happened to do the same task as you are. For a start, I would suggest you to read some articles on ADC characteristics i.e. DC and AC Performance. There are few website that provides excellent explanation on this.
You can go to:
http://www.maxim-ic.com/appnotes10.cfm/ac_pk/2
https://www-inst.eecs.berkeley.edu/~ee247/fa04/fa04/lectures/L11_f04.pdf
http://larc.ee.nthu.edu.tw/~jcbor/MMWirelessIC/MMWIC_lecture32_C3a.pdf
There are a lot more if you try google search engine. The ADC characteristics should includes Dynamic Range, SFDR,SNR,THD,INL,DNL,Offset gain error etc....
These information should give you good starting point.
Then try to read HSpice manual on how to perform Fast Fourier Transform FFT plot. This analysis should give information about AC performance such as Spurious Free Dynamic Range, SNR, noise floor and etc.
For DC performance such as INL,DNL, Im not sure how to simulate using HSpice. But you can use matlab for this purpose...(I guess its much more faster).
HSpice Manual -  http://www.utdallas.edu/~poras/courses/ee6325/lab/hspice/hspice_qrg.pdf
View Profile bincut   IP Logged
Reply #4 - Feb 20th, 2005, 6:05am
Jay,
I estimated the static and dynamic parameters using the method that MAXIM proposed to measure real ADCs in lab. But the matlab program presented on MAXIM's website are for data sampled using a logic analyzer. The transient simulation is printed using .print card in HSPICE. Then the simulation results are read and convert to decimal digits using some programs I had written before.
Good luck!
Yawei
Reply #5 - Feb 22nd, 2005, 10:16pm
Jay,
 In the CADENCE ICX reference ahdl library, there are a dnl
and an inl testbench modules. The current models are rather
limited, for example, 8 bit, single-ended ADCs. However, it is
easy to modify the cells. In an append to another e-mail
thread, an example of a testbench setup for SFDR
was discussed. The same testbench can be used for
measuring THD. However, unless you are performing
transient noise sumulation or are including noise in a
behavioral model and simulating, the SNR simulation is
going to measure the ADC quantitazation noise floor, (not
very interesting).
                                                             Art Schaldenbrand
jay
Reply #6 - Feb 23rd, 2005, 9:20pm
Thank you all, Leyman, yawei and Art.
I think I got decent understanding on those concepts. Also, I've already had some experience with DFT/FFT simulation with spectre, so I wouldn't worry about that too.
Art and Yawei's info is very useful. I was thinking to use matlab for post-simulation processing. But as Art has pointed out the inl/dnl modules, I'll try these first.
thanks again,
Jay
