For a treat.. before you start those steps..
visit
www.nedit.org and download the executable for your OS & platform..
Also down load the contributed patternfiles for Verilog-A and Verilog-AMS..
after adjusting your path so the nedit executable is available on your path.. import the two pattern files (instructions in the file)
and save defaults after importing each..
now in the CIW command line type
>editor = "nedit"
and proceed thru the steps above..
I think you'll be happier with this editor than with vi..
(but I did Verilog-A modelling for 2 years before I found out about nedit in 1999.. )
Jonathan
