Aug 15th, 2024, 6:36am
model voltage controlled capacitor? (Read 9685 times)
nus_lin
Feb 14th, 2005, 6:49am
hi. I have a quesion to ask, and highly appreciate if anyone drop your comments.
i am working on a capacitive sensor, and i need to model it as a time-varying capacitor. i am thinking of model it as a voltage controlled capacitor. this behavior level model will be combined with circuit simulator- cadence to simulate the systematic behavior of my interface circuit. can someone tell me how to create such a model in cadence?
Eugene
Re: model voltage controlled capacitor?
Reply #1 - Feb 14th, 2005, 6:38pm
Do you have access to VerilogA?
nus_lin
Guest
Reply #2 - Feb 14th, 2005, 9:11pm
not sure, need to check it out. what should i do if i have access to verilogA?
  IP Logged
Reply #3 - Feb 14th, 2005, 10:08pm
You can build a charge-based model as described in http://www.designers-guide.com/Modeling/varactors.pdf. In fact, with Verilog-A you can build the time-varying capacitor model directly. If you have Spectre you have Verilog-A.
nus_lin
Guest
Reply #4 - Feb 15th, 2005, 6:30am
thank you, ken.
but as a circuit designing guy, i never create such a fully-customed component before. i just don't know how to access verilogA with cadence, can you recommend some quick online manual or briefly tell me how to do that?
thanks.
HE Lin
  IP Logged
Reply #5 - Feb 17th, 2005, 2:10pm
Well, the Verilog-A manual would be a good start!
Try actually looking at the documentation - either start by hitting "help" in one of the windows, or by typing "cdsdoc" at the UNIX prompt (or openbook if you're using an old version (prior to IC446)).
It's searchable - so you should be able to find suitable references relatively easily.
nus_lin
Reply #6 - Mar 18th, 2005, 7:56am
thank you. Ken and Andrew, I have already finished the modeling of time-varying capacitor.
here i have something to share with other guys who may have similar problems.
Please follow the below steps to create a symbol out of the verilog-a code. Then you can instantiate this symbol in you design and make use of the same.
1)       In CIW, File->New->Cell View
2)       Give a Library name, Cell name and choose Tool as “VerilogA-Editor” from cyclic field and press OK.
3)       This will open a VI editor. This will contain some default lines, delete these lines and paste your verilog-a code in this file.
4)       Save the file by typing :wq in vi editor
5)       This will create a veriloga view for this code.
6)       After few seconds, it will ask if you want to create a symbol view for the same. Press Yes. This will create a symbol view for your code.
7)       You may instantiate this symbol in your schematic and make use of the same.
Hope this helps.
jbdavid
Reply #7 - Oct 12th, 2005, 1:01am
For a treat.. before you start those steps..
visit www.nedit.org and download the executable for your OS & platform..
Also down load the contributed patternfiles for Verilog-A and Verilog-AMS..
after adjusting your path so the nedit executable is available on your path.. import the two pattern files (instructions in the file)
and save defaults after importing each..
now in the CIW command line type
>editor = "nedit"
and proceed thru the steps above..
I think you'll be happier with this editor than with vi..
(but I did Verilog-A modelling for 2 years before I found out about nedit in 1999.. )
Jonathan
jbdavid
