Apr 29th, 2024, 4:03pm
PSRR for OScillator using PXF (Read 1596 times)
ic_engr
Feb 17th, 2005, 7:32am
I ran PSS and PXF for my oscillator. I shose sweeptype as absolute with f=1Hz to 10MHz.
After completion of PXF, the PXF form assks me for selecting the Vsource. I selected the VDD source. It gave me a plot from 0 to 10MHz. Is this the frequency of the VDD from DC to 10MHz or is it harmonic of the oscillator.
The PSRR output shows 40dB at 1Hz and goes dwon to 0 at ~1kHz. from 2kHz to 10MHz it stays flat at ~-3dB.
Can some one explain me what all this is.
What does 40dB reflect in terms of change in frequency of fundamental being 4MHz.
I will appreciate your help on this matter.
Also do I have to select Modulation in the PXF form.
Thx
ic_engr
