zxhelinor
Dear Ken,
Thanks a lot for your reply. In order to understand the test bench for differential input circuit, I construct a simple circuit: an ideal balun from Cadence Analoglib, two input ports to balun are: 1.Pld(differential mode, sine type, amplitude=1.8V): f=5G with source impedance of 100ohm; 2.Plc(common mode, DC type, Vdc=1V): with source impedance of 25ohm; The balun's two outputs are connected to ground through 50ohm resistors respectively. So the differential input impedance is 100ohm, and the common mode input impedance is 25ohm. Then I run a DC and PSS simulation, this time the DC node voltage is correct, but the PSS voltage at the input(Pld) of balun is 1.8V with phase of 270degree. This result surprised me, the expected value observed at input(Pld) should be 1.8V with phase=0 since the port is perfectly matched. Am I wrong in the set up?
Thanks a lot.
zxhelinor
