Apr 29th, 2024, 3:56pm
IP3 in mixers (Read 4153 times)
Superowl
IP3 in mixers
Feb 25th, 2005, 2:13am
I've been noticing that single-balanced MOS mixers have slightly better IP3 than double-balanced MOS mixers. Anyone have enlightenment as to why that's so?
nano_RF
madison
Re: IP3 in mixers
Reply #1 - May 10th, 2005, 11:43am
As for as I know the IIP3 of the mixer or measure of linerity depends on the gate overdrive of the rf input. The higher the overdrive(Vgs-Vt) the better the IIP3 would be.
In single balanced case u might be using a transconductor as a V-I converter,wheras in double balanced case usualy a tail current source is also used for current matching purposes in left and right side branch. or to say to keep the IF amplitude constant. In that case the allowable overdrive of the RF input must have been reduced. And that could be reason for a lower IIP3. In my view if a tail current source is not used than one can expect the same IIP3 in both cases.
I am a self learner of RFIC design, so may be my analysis is fundamentally wrong. But i wish if somebody can correct me if I am wrong.
--Vikas
J
Guest
Re: IP3 in mixers
Reply #2 - May 10th, 2005, 12:17pm
are you assuming the RF goes into the transconductance stage and the LO goes into the switching stage? cuz that's what I was assuming.
  IP Logged
nano_RF
madison
Re: IP3 in mixers
Reply #3 - May 10th, 2005, 12:39pm
yes I am assuming that RF is fed in to V-I converter and LO to switching .
J
Guest
Re: IP3 in mixers
Reply #4 - May 10th, 2005, 3:29pm
The higher the overdrive(Vgs-Vt) the better the IIP3 would be .. can you refer to me a source that talks about this?
How would you determine the overdrive of current source, and why does a transistor have more overdrive than a current source?
  IP Logged
