kamesh419
[quote author=ramus12 link=1109451125/0#0 date=1109451125] What is the best way to specify inputs for simulation of a 64 bit adder using Spectre circuit simulator? [/quote]
First try to make a file in ASCII with digital inputs for A, B and Cin individually. Then you can convert that file into voltage sources (Time-Value pairs) using any scripting language. Then you can use 'vpwlf' source in cadence to read directly from a file that you have created. This according to me is the simplest way. probably some body else can throw some more light on this.
Bye kamesh.
