May 17th, 2024, 9:39pm
spectre circuit simulator (Read 2019 times)
ramus12
Feb 26th, 2005, 12:52pm
Hello all!
What is the best way to specify inputs for simulation of a 64 bit adder using Spectre circuit simulator?
thanks!
Ramus
kamesh419
Re: spectre circuit simulator
Reply #1 - Mar 1st, 2005, 7:45am
[quote author=ramus12  link=1109451125/0#0 date=1109451125]
[/quote]
First try to make a file in ASCII with digital inputs for A, B and Cin individually.  Then you can convert that file into voltage sources (Time-Value pairs) using any scripting language. Then you can use 'vpwlf' source in cadence to read directly from a file that you have created.  This according to me is the simplest way.  probably some body else can throw some more light on this.
Bye
kamesh.
Truth lies everywhere and partially even with the error.
