May 16th, 2024, 12:21pm
PFD phase domain model (Read 2375 times)
Tommy
Guest
Feb 27th, 2005, 6:07pm
I want to simulate lock-up time of a PLL using phase-domain models. I am thinking of writing a Charge-pump/PFD model to do this. Any suggestions & help are most helpful & welcome.
Tommy
  IP Logged
gogomi
Re: PFD phase domain model
Reply #1 - Feb 28th, 2005, 11:20am
Hi, Tommy,
I am working on phase-domain modeling too. You can
refer to the pll library paper from Cadence. But I think
if you would like to make a use of it, you probably need
to make some modifications on the codes. You can find
the paper at
www.cadence.com/whitepapers/pllapp_note.pdf
gogomi
