May 16th, 2024, 3:08am
Reducing Voltage Source Noise (Read 48 times)
Roby
Feb 28th, 2005, 10:11am
I am trying to measure Current response of a tunneling junction by sweeping the voltage from 0 to 0.5V. I measure the noise of v-source alone and found out that it is too high. Can i connect a capacitor across the DUT while taking teh measurement (which is equivalent to  a high resistor) to reduce the noise.
Roby
August West
I'll get up and fly
away
Re: Reducing Voltage Source Noise
Reply #1 - Feb 28th, 2005, 12:08pm
You can if ...
1. the bandwidth of the resulting RC filter has appreciable attenuation at the frequency of interest.
2. the currents that flow as a result of inserting the capacitor do not in turn cause their own problems.
-August
