May 6th, 2024, 7:56am
Modeling PLL phase noise with Verilog-A (Read 4498 times)
Samir
Cairo
Mar 07th, 2005, 6:09am
Dear Sir,
       I read the "Predicting the phase noise of PLL-based frequency synthesizers " paper, but in modeling the noise of each block some functions, like "flicker_noise", which is available in Verilog-AMS.
But I am using Verilog-A, so if there is any other method to describe the noise of each block ??
Thanks for your concern
Mohammad Samir
Re: Modeling PLL phase noise with Verilog-A
Reply #1 - Mar 8th, 2005, 1:27am
I believe everything in the paper can be done using Verilog-A. flicker_noise certainly does exist in Verilog-A. In other words you should be able to do this with spectre, rather than requiring AMS Designer.
