Jul 25th, 2024, 6:02am
Preemphasis and equalizer  in the SerDes desi (Read 9841 times)
raymond_luo2003
Mar 14th, 2005, 4:04am
Dear all,
I am working on the high speed SerDes design. I got some papers which mention about using the pre-emphasis and post-equalizer to improve the eyediagram at receiver side which is attenuated by cable loss.
Altough that  makes sense to use those types of techique, I feel it is quite challenging to implement it.
a) Usually we require the one original serialized data stream and one (or more than one, depends the FIR structure) very short precised delayed serialized data stream with coefficient a to bulid FIR. I just wonder how to implement the precise delay line under PVT variation?
b) Another methodology is to delay parallel data before the serializer which let us use the low frequency clock for easy implementation. The issue of this is we have to duplicate an entire serializer only for generatiing the delayed  serialzed data stream. It is big area and power copnsumption!
Anyone got relevant rexperience would help me a lot!!
Raymond
Re: Preemphasis and equalizer  in the SerDes desi
Reply #1 - Mar 15th, 2005, 7:26am
Hi, Luo,
Several year ago, I worked on some Serdes designs. I don't think it needs precise delay for pre-emphasis. Pls refer to any DSP textbook. The input should be delayed for one cycle, two cycles, ..  So it is not difficult to implement a pre-emphasis in Serdes.
Best regards,
Yawei
raymond_luo2003
Reply #2 - Mar 15th, 2005, 7:41am
Ya Wei,
Very much thank your suggestion. In the high speed SerDes, up to 3Ghz, we usually use multiphase clocks for MUX(serializer)  to relieve the demand of single high frequency signal which is quite difficult to be generated.
This mean we don't have the  clock whose frequency is equal to data rate. We only have the multi-phase clocks, say, 4 clocks with 1/4 data rate frequncy.
So to generate a delayed data stream become power and area hungry as we need build a additional serailizer , or otherwise we need one bit  data timing shifer ( like a a analog type shift register).
Any good idea?
Thanks and best regards,
Raymond
But my concern is, it is quite difficult
Reply #3 - Mar 15th, 2005, 9:01am
Hi, Luo,
Why do you think it is difficult if you have multiphase clock? I think it is almost as easy as you have a single phase full rate clock. A serializer itself is very small. I think that is OK if you duplicate a serializer and convert the delayed parallel data to serial.
By the way, it is still feasible for a 4X3.125G Serdes using a full rate CDR and with a transmitter using a full rate frequency synthesizer.
Yawei
raymond_luo2003
Reply #4 - Mar 15th, 2005, 9:29am
Hi, YaWei,
Well, you should be right.
One practical problem is to generate a delayed version serilized data stream: Let us consider a practical case,
Suppose the basic serializer structure as follow
8:1 MUX + Pre-driver+ Liner driver
Data stream
dPn[7:0] @ 500MHz ==> dSn[0]@ 4GHz
The "n" of dPn[7:0] stand for this is the nth 8 bit parallel data.  dPn stand for the parallel data, dSn[0] stand for the high frequency serialized data stream.
In order to build a delayed version serialzed data, we firstly  need a parallel  data shuffle to build a new arranged parallel data.
NEW dPn[7:0] == dP(n-1)[7] + dPn[6:0]
NEW dp(n+1) [7:0]== dPn[7] + dP(n+1)[6:0]
Then again we need a entire serailizer to serailize the NEW parallel data to get the delayed version data stream.
I thought the above structure require double area + double power, even more if we consider the new parallel data shuffle. Is this price too high for a only one-taped premehasis? If we need a 2 taped pre-emphasis, we need third serializer, am I right?
Look forward to your reply.
Thanks!
Raymond
DReynolds
Scarborough ME
Reply #5 - Mar 24th, 2005, 6:47am
Raymond, on the transmit side pre emphasis has been very popular because it is very cheap in terms of harware, power, etc. All you need is a flop to delay the data and a scaled cml driver that sums with the main signal. If you look at the red rag papers on designs running at >~2Gb/s you should find examples of this....
The issue with tx based equalization is that you have to know  ahead of time how much emphasis to add... does your application allow for this?
David Reynolds
raymond_luo2003
Reply #6 - Mar 24th, 2005, 9:45am
David Reynolds
Very much thanks your reply. May I have a example from you as you mentioned " red-rag" paper?
I am keen to see that since I got pressure to finish my architecture soon.
Can you explain your suggestion below  a little bit more detail since I don't quite follow you.
Thansk!
Raymond
DReynolds
Scarborough ME
Reply #7 - Mar 29th, 2005, 5:04pm
Raymond, if I want to make a output and I sum a*d(n) + b*d(n-1) I will make a pre emphasis circuit.  Total power in the output stage is fixed so a +b =1, but I can make b be say 10-30% of total power to create a pre emphasis output. The amount of pre emphasis needed is a function of the length of the channel: longer channels have higher losses and require larger amounts of pre emphasis.
Since you only want to emphasize bits when they change state, a simple exor gate is all that is required to decide when b !=0.
hope this helps
David Reynolds
ps. "red rag" is slang for the journal of solid state circuits... sorry if I was not clear.
neoflash
Mixed-Signal
Designer
Reply #8 - Nov 11th, 2005, 6:50am
[quote author=raymond_luo2003  link=1110801864/0#4 date=1110907777]Hi, YaWei,
Data stream
Thanks!
Raymond
[/quote]
Your need a FIR to do pre-emphasis. And you need to delay the data.
You can use half-rate clock to retime data if you have.
You can also retime data by multi-phase clock in lower speed.
You might not be recommended to do 8:1 mux directly, because that will make delay hard to be get.
There is trade off, you can not have all in the same time.
