May 18th, 2024, 12:35am
A simple question. (Read 2780 times)
James
snowfiled
A simple question.
Mar 25th, 2005, 7:28am
For a common Source stage Amplifer with Resistive Load Rd.
It is said in Razavi's book that:
For large values of Rd, the effet of channel length modulation in the transistor becomes significant.
Why does the effet of channel length modulation become large for Large Rd?
many thanks
James
Re: A simple question.
Reply #1 - Mar 25th, 2005, 9:27am
The model of the output of a common source amplifier is a controlled current source in parallel with a resistor, ro. The channel length modulation determines the size of the resistor. The more channel length modulation, the smaller the resistor.
If the load resistor Rd is small, then it overwhelms ro. If the load resistor is large, then Rd does not overwhelm ro, meaning that ro affects the overall gain, distortion, etc.
James
snowfiled
Reply #2 - Mar 25th, 2005, 4:51pm
Thanks, your explanation is very clear. I fully understand it now
James
