stephen
I've got another question about Assura. I've always used Diva up to now and I've decided to try Assura. I think we have license for Assura. However, I don't know where to find it or how to launch it. I checked the manual and it says that it should be available from the tools menu of the Virtuoso layout editor. However, I can't find it.
Please help.
[quote author=Andrew Beckett link=1090724471/0#1 date=1090964953]You didn't say which verification tool you are using.
If using Assura RCX it isn't blocking, so I assume you're talking about Diva?
You should be able to use the Remote Diva capability (there's a menu for this on the verify pulldown, I think). (even if it is to the local host) which would background it (I think). Alternatively you could extract using the ivVerify command in UNIX. In that case you wouldn't be able to have the layout open for edit whilst you are doing the extraction.
I'm saying this from memory, so it may not be exactly right.
In future, please remember to say which tools you are using - extraction can be performed by Diva, Dracula, Assura, Fire and Ice, Hyperextract, to name just the Cadence products - and there are others - without even going into non-Cadence tools. Otherwise it is very difficult to give you the answer you're looking for.
Andrew. [/quote]
