May 17th, 2024, 11:00pm
About ADC's FFT and crosstalk (Read 8382 times)
fangjh
hefei china
Mar 29th, 2005, 6:27pm
I have two issues:
  1) When I  calculate ADC's(8bit)  FFT, I should use at least 512 point,but in fact I use 400 point, because the input and sample frequency is not match, and test equipment 's speed is not enough, the result become bad or good? why?
  2) How to calculate two channel ADC's crosstalk(how to define), and I how to test ???
  I am glad to receive your solution
fangjh
hefei china
Re: About ADC's FFT and crosstalk
Reply #1 - Apr 6th, 2005, 12:04am
please help me, thanks, I only want to the vary direction.
Reply #2 - Apr 7th, 2005, 2:17am
Hi, Fang,
Are you runing SPICE simulation or lab measurement?
I don't understand why do you have only 400 point. Pls go to maxim's website for applications about ADC test.
About the crosstalk. I think you must make one has zero input, and another has near full scale input. Then sample the first ADC and calcultate the output signal.
Best regards,
Yawei
fangjh
hefei china
Reply #3 - Apr 7th, 2005, 4:51am
thank for ywguo's answer
 1)I use 400point to calculate is not used in Hspice,  is used in matlab in actual test. because the test equipment's speed is not so quick, the data will be errors sometimes. so I select some correct data to calculate, but I don't know the result  is godd or bad.
2) I have test  crosstalk follow what you said, but how can I  know the result is good or bad. Such as 50db in AD9883's result.
analogic
Reply #4 - Apr 12th, 2005, 7:25pm
you said ----
-- i m confused by your question, why not to capture more data for FFT analysis. It is better to use a sample number which is power of 2 for FFT. Even 512 is too few. You need 4096 or more to get good frequency resolution. Please read some application notes before you jump into testing.
you said --
-- crosstalk is always undesired, so the lower the better. you cannot say it is good or not without referring to a specific application.
hope it helps.
fangjh
hefei china
Reply #5 - Apr 12th, 2005, 10:29pm
Thanks analogic's help
1)FFT should to  use a sample number which is power of 2 for FFT. 4096 is more better. I kown this. In fact, I
use 400 point to calculate because of actual equipment's limit ,so I have use 400 point with hann window in matlab, the result is beter or worse than use 4096;
2) ADI’s AD9883 the crosstalk is 55db, I want to know how to calculate the parameter.
« Last Edit: Apr 12th, 2005, 11:44pm by fangjh »
analogic
Reply #6 - Apr 13th, 2005, 8:56pm
-- worse. the more points, the more frequency resolution. for example, you will not see harmonics if the sample number is small.
-- i guess, say u have 2 channels, apply signal only at channel 1, measure output of channel 1 (P1) and that of channel 2 (P2).  10log10(P1/P2) is crosstalk.  it may not be exact definition of crosstalk, but should help to characterize it.
Reply #7 - Apr 14th, 2005, 9:32pm
Analogic,
 Basically, the definition is up to you. If you look at the AD9229, there
AD defined the crosstalk as the signal on a quiet channel when the adjecent
channel is driven by a full scale signal.
fangjh
hefei china
Reply #8 - Apr 17th, 2005, 6:37pm
Thank everyboday's help!!!
 1)I thank that the harmomic will alias signal when  sample and input ratio is not large(eg: 2~4) in little point. That is right or not.
 2) I have test two channel.  I sent full range(1 Vpp) to 1 channle, and test 2 channel  always jump 1 LSB.This crosstalk is ???
Reply #9 - Apr 17th, 2005, 7:04pm
Fangjh,
1) When simulating, a 256 point FFT should have enough resolution
   provide you all the information you need, at least for 10 bit, Nyquist
   type ADCs.  I usually see the FFT noise floor at about -100dB for
   a 256 point FFT and this is enough resolution.
   You do need to be careful about input frequency selection. The correct
   simulation setup has been discussed on other threads. The point is to
   avoid windowing if you can, that is, when simulating setup to use
   the rectangular window. Unfortunately, when using measured data
   this may not be possible.  However, a 256 point FFT should still
   provide useful information even when using measured data.
   The frequencies do "fold" back into the  FFT spectrum. Not sure what
   the concern is, are you somehow post processing the data digitally to
   remove the harmonics at high frequency? If not, you should include the
   effect of distortion in your effective number of bits calculation.
2) My guess is that 1dB lsb of crosstalk is real bad, the AD9229, had
   -95dB of crosstalk.
