Fangjh,
1) When simulating, a 256 point FFT should have enough resolution provide you all the information you need, at least for 10 bit, Nyquist type ADCs. I usually see the FFT noise floor at about -100dB for a 256 point FFT and this is enough resolution.
You do need to be careful about input frequency selection. The correct simulation setup has been discussed on other threads. The point is to avoid windowing if you can, that is, when simulating setup to use the rectangular window. Unfortunately, when using measured data this may not be possible. However, a 256 point FFT should still provide useful information even when using measured data.
The frequencies do "fold" back into the FFT spectrum. Not sure what the concern is, are you somehow post processing the data digitally to remove the harmonics at high frequency? If not, you should include the effect of distortion in your effective number of bits calculation.
2) My guess is that 1dB lsb of crosstalk is real bad, the AD9229, had -95dB of crosstalk.
