May 3rd, 2024, 6:35am
Different Process Technologies on Single Chip (Read 1039 times)
Vishwanath M
Guest
Apr 04th, 2005, 1:48am
Hi Friends,
I have one query, Can I have different Process technologies like 0.18um, 0.13um, say for example OpAmp I will place half transistors with 0.18um and remaining with 0.13um.  Is it possible to fabricate?
Thanks in Advance....
Vishwanath M
  IP Logged
DReynolds
Scarborough ME
Re: Different Process Technologies on Single Chip
Reply #1 - Apr 4th, 2005, 6:03am
Vishwanath,  the short answer is no, you can't have different processes on a chip, however, you can of course draw a .18um transistor on a .13um design. Another exception is that most fine line processes have dual gate oxides ( a thin one for regular circuits, and a thicker one for IO) in this case you really can have two different  devices like .13um and .35um(3.3v) on a chip.
hope this helps
David Reynolds
Vishwanath M
Guest
Reply #2 - Apr 6th, 2005, 3:25am
Hi David Reynolds,
If we can have 0.13um for core logic (thin oxide) and 0.35um for I/O Pads (Thick Oxide) on a chip. Why can't have two process technologies.
If not! is it fab problem or other problem..
Other view...
From simulations point of view we can do using two process technologies using spectre.
After this, face problem arise to do extraction/LVS....
Is it true what I am saying....
Thanks for your replay....
Vishwanath M
  IP Logged
Paul
Switzerland
Reply #3 - Apr 6th, 2005, 5:44am
Vishwanath,
I am not sure to understand you correctly. It is not possible to use different manufacturing processes on a single wafer because there is very little need. As in 0.13um technology you can draw your device's channel length whatever you want, provided it is larger than 0.13um, I don't see the reason why you would like to have 0.18um technology devices...
The reason to provide "0.35um devices", which have thicker gate oxyde, is to have convenient voltage levels to communicate with the outer world. Applying the 3.3V I/O voltage to 0.13um devices would break down the gate oxyde very quickly.
Could you share the reasoning behind your question, please?
Paul
Vishwanath M
Guest
Reply #4 - May 2nd, 2005, 12:18am
It is only knowladge....
Thanks Paul...
  IP Logged
