May 3rd, 2024, 2:34am
Calculting PSD for non periodic data (Read 34 times)
HighwayStar
Guest
Apr 19th, 2005, 3:40pm
In "Predicting the phase noise and jitter of PLL-based Frequency Synthesizers", the matlab script for computing Sphi (delta_f) makes use of the periods.m file to calculate the psd. It makes the basic assumption that the consecutive transitions have approx. same width (period).
If my PLL is in a CDR circuit, for which the consecutive transitions are not always periodic, How should i modify the script? I mean to say that my OSC signal is not from a clock, but is actually a data stream which may have a runs of 1 or zero.
Thanks.
  IP Logged
