May 19th, 2024, 9:19pm
Corner simulations in Spectre (Read 3326 times)
Alez
Guest
Apr 29th, 2005, 12:54am
Dear all,
I plan to test (in simulation) my circuit with varying all cases
of the provided transistor model, e.g. FF/SS/SF/FS.
Could you suggest me how to do this in Cadence Spectre ?
Thank you in advance,
Alez
  IP Logged
Paul
Switzerland
Re: Corner simulations in Spectre
Reply #1 - Apr 30th, 2005, 12:52pm
Alez,
If you searched this forum for "corner simulation", you would have found the following post:
http://www.designers-guide.org/Forum/?board=ms_design;action=display;num=1074857...
For the exact simulation set-up and the parameters to be set, you will find it in the Cadence Advanced Analysis Tools User Guide, Chapter 1, Corner Analysis. In ADE, select Tools->Corners. One suggestion: use a configuration file (PCF file) to set the corner information in the corner tool, instead of filling in the information by hand. It is easy to write (get inspiration from the User's Guide) and much more flexible if you want to add variable sweeps.
Paul
Alez
Guest
Reply #2 - May 3rd, 2005, 11:26pm
Thank you Paul. This helps on my simulation a lot Smiley
  IP Logged
