Paul
Hello Packiaraj,
the settling time is related to the UGF through the settling error you can tolerate. Your specifications should define that error and the settling time, from which you can then calculate the required UGF. It is difficult to judge if your results are correct without knowing your target settling error, but the values you mention sound reasonable to me.
Paul
