Jul 16th, 2024, 8:16pm
why Assura DRC hangs (Read 3104 times)
asdf
Armenia
Jun 15th, 2005, 2:08pm
I hope anyone will help
I have a problem with Assura DRC in interactive mode.
When running DRC at second time the program hangs
each time I have to kill icfb (or others) and run it again
have any one met such problem?
thanks Smiley
Bergerak
View Profile marimna   IP Logged
Re: why Assura DRC hangs
Reply #1 - Jun 15th, 2005, 10:54pm
Yes. It's solved in Assura 3.1.4.
Alternatively, you should be able to do:
setenv ASSURA_UI_NONMEMDATA 1
before starting DFII - this tells Assura to do the DRC externally rather than in memory, and that works too.
