Jul 24th, 2024, 12:30am
problem with ideal switches in Cadence (Read 1356 times)
vivkr
Jul 04th, 2005, 5:58am
I wonder if anyone has experienced a similar problem using the special
"sp1tswitch" provided with Spectre. This switch is useful if you want to configure
a netlist differently for different analysis and very useful.
However, if I have any such switch in my netlist (even one completely isolated from any net), Spectre refuses to perform a noise analysis citing a singular matrix as the source of error.
Any suggestions will be welcome.
Vivek
Re: problem with ideal switches in Cadence
Reply #1 - Jul 5th, 2005, 3:47pm
It appears to be a bug. You should report it to Cadence.
jbdavid
Reply #2 - Oct 2nd, 2005, 6:25pm
that element is OK.. but I found Verilog A to be much more flexible..
for an example,  there is a listing for a loop-opener in the  paper below which includes an (outdated) example of its use.
"Functional Verification of a Differential Operation Amplifier"
... a fully differential current mirror opamp with n-channel input devices ... support the development of a verification script. Figure 1 Fully Differential Current Mirror Opamp with CMFB The following table ...
http://www.cadence.com/whitepapers/FVofDiffOpAmp_wp.pdf - 309.8KB
Outdated because today one would use the STABILITY analysis to look at loop gain and phase margin..
JBD
jbdavid
Reply #3 - Oct 2nd, 2005, 10:55pm
It just occurs to me that if you have a switch isolated in a circuit, then it will result in a singular matrix unless both ends of the switch must have DC paths to ground.
jbdavid
Reply #4 - Oct 3rd, 2005, 11:28pm
sounds like bmslib sw_no would be a good alternative in that case..
jbd
jbdavid
