Also, the above subckt can be simulated directly in spectre with no syntax changes from IC5141 onwards. In IC5141, you need to do:
Code:spectre +csfe netlist.hsp
whereas in the latest simulator release, MMSIM60, the new front end (enabled by +csfe in IC5141) is on by default. The new front end gives improved performance (memory and speed) in the netlist parsing of spectre syntax, and also supports natively SPICE syntax files.
This is of course with Ken's proviso taken as read.
