May 18th, 2024, 7:33am
Estimating bottom plate capacitance (Read 2576 times)
vivkr
Jul 14th, 2005, 11:08pm
I am looking for a reliable way to estimate the bottom plate capacitance of poly-poly caps. Usually, I just assume a worst-case estimate of 10% which although conservative is not a problem as I never really have to deal with extremely large caps and this approach also accounts for extra caps from the layout.
However, I am currently working with very large on-chip caps (~1 nF) and I think it would be better if I could get a more realistic estimate. I have data about field oxide thickness vs. poly-poly oxide thickness. However, I dont have much information about the permittivity ratios. Is it wise to assume that the ratio of bottom plate cap to nominal cap would be in ratio of the oxide thicknesses?
Vivek
rf-design
Reiner Franke
Re: Estimating bottom plate capacitance
Reply #1 - Jul 18th, 2005, 12:23am
Modern process have about eps=4.2 between thin film layers (metal&silicon). Lateral between the fill glass have about eps=4.1. Field oxide possible under doublepoly cap have eps=3.9. The thickness of the thinoxide is difficult to measure and then calculate. So use instead the direct cap measurement. Be aware that the silicon undernead the field oxide have also a series resistance. So it could lower significant Q of the cap.
DReynolds
Scarborough ME
Reply #2 - Jul 20th, 2005, 6:41am
Vivek, in the documentation for the process you are using should have capacitance tables that include poly_to_field which you can use to caluculate the capacitance exactly if you know the size of the poly-poly cap you are making.
David
