Jun 30th, 2025, 2:41pm
wreal in digital context (Read 2187 times)
Monia
Guest
Jul 22nd, 2005, 9:05am
I have the following code:
real sample, OutInt;
wire dsample;
always @(posedge dsample) begin
 OutInt = sample;
 <other digital setting>
where "sample" is controlled in another process and
it has a behavior like a step.
Instead OutInt is changing even if dsample is stable
and it behaves like a ramp.
Can you explain me why?
I'm expecting OutInt stays constants and it changes
only @ posedge of dsample.
  IP Logged
jbdavid
Re: wreal in digital context
Reply #1 - Aug 3rd, 2006, 6:18am
Are you SURE the value is changing between, or is your Waveform viewer "connecting the dots" between the values..
This is the simvision default setting for real and wreal signals.
jbdavid
