May 17th, 2024, 8:42am
Spiral inductors and EM-noise (Read 2631 times)
Paul
Switzerland
Aug 10th, 2005, 3:04am
I am using spiral inductors for peaking purposes in a high-speed (GHz-range) amplifier and I was wondering whether it might pick up ambient EM noise that could perturbate the signal. The design is fully differential for supply and substrate noise rejection and the inductor therefor is a t-coil type structure.
Has anybody experienced such problems or suggestions to avoid this problem. Or isn't this a real issue after all?
Thanks in advance for your comments.
Paul
neoflash
Mixed-Signal
Designer
Re: Spiral inductors and EM-noise
Reply #1 - Nov 6th, 2005, 6:01am
Generally it is not an issue, since the signal in your CML stage is digital signal instead of RF signal.
If you are treating with small signal such as LNA, you can add inductor ground shield, and place inductors far enough.
How far is enough? That is a question. I will use suggest 200um as the bottom line, if your inductor is 100um square.
Paul
Switzerland
Reply #2 - Nov 8th, 2005, 12:01pm
Thanks for your answer, that's more or less what I was looking for.
Paul
