Linus
Guest
Hi All,
I am looking for different topologies integrating a differential interface with the following requirements:
- differential interface with on-chip 50 Ohm termination - very small power consumption - the differential signal provides is switched current source with 5mA. both input lines are externally terminated with 50 Ohms to 3.3V. - the input frequency is 400 MHz
What kind of topology would be the best as the complete system is very jitter sensitive ?
Thanx for the hopefully incomming answers,
Linus
